Google tts issues
hey all,
since a week or so, google tts app doesnt work all the time. i mean, the app works but the text wont be spoken. i think an issue at google but is it? more people with these issues?
yes, and also many times mentioned in several posts. Hint: use the magnifying glass in the upper right corner and type tts
i did… i am not stupid… i even ordered in time, newest first… nothing showed up. that is why i posted this.
but thnx for the confirmation.
So this came not in the search results?
Even a topic just about Google TTS, hmmm.
@Edgar my google mini hub also suddenly not working 3-4 days ago not sure what happening. :face_with_raised_eyebrow:
check previous comment :wink:
Thanks, i was reading the threads…try figuring how to do the setup :face_with_monocle:
Hi All,
Since the app was updated recently, it does not work anymore. Any suggestion?
ec72f76f-0e2c-4f06-89e8-4446fc18ba78
Thanks!
Quin
Yes, you have to look at your flowcards, they have got a different Lay-Out, there are changed and added fields that have to be filled-in.
the field in ‘blue’ must be filled with a Boolean (Ja or Nee) or a Boolean Tag.
The lower field must also be filled with a Boolean Tag, ( Ja or Nee does not work here with the web-app).
Edit: with the mobile-app, the fields can be changed, no variable (tag) needed.
