Since this evening Google Home is not executing Homey Flows anymore.
I have several voice commands in Google Home that starts Homey Flows.
This morning everything was working file. When i ask Google Home to open the Blinds, that works.
However when i asked this evening to close them, i got a confirmation from Google Home, but nothing happens.
I tested further, and came to the conclusion that Google Home does not execute Homey Flows anymore.
So somewhere there is a communication problem between Google Home and Homey.
When you can direct access a module (light on/of) that works fine, but when you want a flow to start, that does not work.
I also entered a support ticket for this…
Henk
Is Google Home still connected with Homey (it is still turned on in the settings of Homey, reset Google Home, reset Homey, tried to sync Google Home with Homey?
Tried all this?
Everything is connected and Sync. Everythis resettet but nothing helps…
Henk
I am having the same issue. The last time I remember giving a successful voice command was Sunday afternoon. Monday afternoon, commands stopped working, and still don’t work now. Even manually triggering the Automation inside the Google Home app does nothing. It’s like Google Home is no longer able to trigger Flows at all.
The problem is that Google Home is changing to Gemini. In the old-editor you could do more that the new editor.
I have entered a support ticket and they are investiging.
But i found a way to overcome this problem.
You first make a flow in Homey and make i a Favorite. Then Sync with Google Home (in case it does not do this automatic).
Than you say "Hey Google, Start Flow FLOWNAME "
And then the flow is started.
Henk
The workaround is working for me too.
Same Here ! From one day to another the automations by voice or manually stopped working and now I can’t run the flows by voice !
Any news if this is going to be solved ?
JoBE
September 2, 2026, 8:23am
8
It does not work for me but i have not made a new flow, just used the old one. Maybe i need to redo the flow, or?
Any news about this problem of the google home?
No, there are still investigating this…
