Google Home, after connection there is an error
Homey Pro was always correct connected to Google Home. and of yesterday only 50 devices out of the 185 there were on there the day before.
I tried to resync with the connection i had, not working.
than in tried to reconnect. log of log on, not working
than i removed the connection, like i didn’t a ton of times, and reconfigure. not working,
connection is made, than there was an error try again.
I tried a compleet separate account, clean account to connect to homey, same problem.
the problem there are nog logs, or error’s that will help de search for a solution. online there allot of tricks you could try I dit all off them. about serveral times.
the only thing i now could do is wait a couple of days and check if somthings will change.
Anybody an idea what is going on.
When your Homey Pro actually is a Pro 2023: You could try this firmware update:
