Getting the device by its id takes a long time
It might be that we’re talking about this issue to further our understanding of HomeyScript, for which I absolutely support that. However, if we’re concretely discussing how to relatively dim some lights based on input, it feels better to just use flow cards?
Hi Articate,
In normal cases your card would probably be fine. Since this is about two plafonds with three lamps each my dimming ‘algorithm’ needs to do more than a simple fixed value dimming. The 20% I used was more of a testing value and not evident in my test code above.
Good call though.
So you’re going to scale a max dim for each individual plafond or something? Like, that some plafond can go to 100%, but others only to 70%? and then if you dim 20% from 100% that’s 80%, but 20% from 70% would be 56% instead of 50%, is that what you want to achieve?
I need to experiment a bit to see where I will land with how the dimming algorithm will work in the end.
Since each plafond has 3 ikea lamps there is lots of room for how to execute the dimming. In my last dimming step only one of the 3 lamps is lit 5% (ikea lamps turns off lower than that) and that is a perfect level for movie nights or similar where only a guide light is necessary. On the other hand the 3 lamps in the plafond at 100% each serves its purpose as well. Everything between those levels and number of lamps will take some time to figure out since I only want to deal with no more than 4-6 levels to work with.
I have two of these plafonds in my living room but only one is ‘smart’ at the moment and since they each cover half of the room I want to come up with something smart in the end. I’m also considering replacing one of the lamps with its rgbw version to get a bit more variety at night. Time will tell…
Hi @Joka
I just thought of the fact the Papertrails app, can log time in ms;
so no stopwatch or timestamp-script-cards are needed for measuring flowcards or scripts :upside_down_face:
log:
2022-07-14 16:04.43.430		TurnLightOn start (script-monitor)
2022-07-14 16:04.43.937		TurnLightOn_FilterDevices - runtime (script-monitor )
2022-07-14 16:04.45.053		TurnLightOn_LoopOverDevices - runtime  (script-monitor )
That’s true but especially for this case I like to get a notification directly with the calculated runtime.
