Get query to my ecoflow River Pro
Hello
In my homey pro I want to to do a flow to get the level of the battery in my ecoflow: if battery level is lower than 20% send me a message. How can I do ? Ecoflow gave me this request below and I don’t know how to use it in my homey pro. Someone could help me ? Than you very much. Best
curl -X GET \ https://api.ecoflow.com/iot-service/open/api/device/queryDeviceQuota?sn=ABC \ -H ‘Content-Type: application/json’ \ -H 'appKey: 123456’ \ -H 'secretKey: 123456’
Hey, there are quite some examples for fetch through HomeyScript.
You might want that, since its just a request that you need executed.
(Sorry for the short answer, but i’m on my phone)
Thank you very much for your help. I install HomeyScript, I took the exemple “example-fetch.js” and replace the fetch of the example by curl -X GET \ https://api.ecoflow.com/iot-service/open/api/device/queryDeviceQuota?sn=MYSERIAL \ -H ‘Content-Type: application/json’ \ -H 'appKey: MYAPPKEY’ \ -H 'secretKey: MYSECRETKEY’ and it’s not working. I m not a coder so I don’t understand much about it. Do you have an idea how to write the code as it’s work ? Thank you very much.
Yeah, ill take a look tomorrow.
You need to fill in the serial, key and secret.
But then it should work, i get a correct deny.
const res = await fetch('https://api.ecoflow.com/iot-service/open/api/device/queryDeviceQuota?sn=MYSERIAL', {
  headers: {
      'Content-Type': 'application/json',
      'appKey': 'MYAPPKEY',
      'secretKey': 'MYSECRETKEY'
if (!res.ok) {
  throw new Error(res.statusText);
// Get the body JSON
const body = await res.json();
console.log(body);
Hello, thank you so much. I will try it, keep you in touch. Best
I have this output : { code: ‘6047’, message: ‘device does not exist’ }
I will check with the manufacturer
Best, A
Hi Calbo,
i just wanted to know what Ecoflow wrote and whether you were able to put together a useful query here?
Ecoflow now offers an API interface in the developer forum where you can generate the app-key and secret-key yourself. Together with the registered devices it should work, but I don’t have any programming experience or only read experience. I would therefore be interested to know whether there is already a code or instructions for displaying the devices/values using the API.
Best regards
Christian
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum! post here.
Apps can be requested at Athom or at users, like mentioned in the Welcome to the forum! post.
