We work a lot with Ecoflow PowerOcean.
I would like to see an Integration for PowerOcean and PowerInsight Touchscreen.
The PowerInsight has also a Matter Hub Insight.
Some Important features i like to see:
read the Inverter Data like Solar Production, Power Consumption, Battery level
Tell the Battery to charge & discharge
Easy Tibber Integration for the Battery
And nice to have: control your Homey Devices and flows with the PowerInsight Display
Thank you for your feedback! I’ll make sure to add it to the list.
Additionally, it’s worth noting that the integration will be bidirectional. We’ll ensure that EcoFlow devices can be added to Homey, and EcoFlow will use the Homey WebAPI to integrate Homey-connected devices within the EcoFlow App and Powerinsight Display.
I’ve been hoping for some time that the two systems could communicate with each other, but unfortunately I don’t have the knowledge to configure the Ecoflow API myself.
My wishes are probably a bit obvious… and are probably already planned.
I use a couple of solar panels on the Powerstream inverter, have a Delta 2 Max with an additional battery connected to it and there are a couple of smart plugs in use.
I have also switched to a dynamic electricity tariff. So it would be great if I could prioritize storage in times of low electricity prices and low solar yield, in order to have more battery charge in the evening hours when prices are higher. The flow for this would not be a problem if I could access the battery status and the input power of the panels in Homey, and of course prioritize the electricity storage/supply or adjust the base load over the API.
In principle, of course, the entire range of functions would be interesting, which is also available via the official Ecoflow API.
Ideally, the interface to the dynamic electricity tariff already exists.
I am very much looking forward to the integration of Ecoflow and would of course also offer myself as a test user.
Like Hubi also said, of course we’d prefer to have all the functionalities that these devices also have via the Ecoflow app.
The most important features for me are cards for:
Delta 2:
-Charging speed (not sure if via the API it can be set lower than 200 watt? I would prefer it to be in less coarser steps and also lower than 200, because if it is cloudy then I might just have 200 watts coming from the roof and I would like to keep using that to provide my baseload besides charging).
-Turning the AC output on/off (I have an appliance directly connected which draws more power than powerstream will deliver).
-Pauze charging (I believe this isn’t available from the Ecoflow app, so that’s why I currently use a smart plug, but I see the functionality in their developer API, I rather manage this via a flow talking to the Delta directly).
-Charge percentage
-Discharging power
Powerstream
-Adjusting the base load
-Switch power supply mode
We’re in the final stages of integrating the devices. It’s important to note that the first version of the EcoFlow app will only be compatible with the PowerOcean devices. Their Business API, which supports OAuth, is currently limited to PowerOcean integration.
We’ve provided feedback to EcoFlow, expressing our interest in integrating their other product lines. However, these are not supported by the API at this time.
That’s a bit dissapointing. I expect there will be a lot more ecoflow users without power ocean systems than the other way around. But as the power ocean is intended for home use, it’s also understandable…
Hello.
I have a delta pro. do you have plans to add this to the homey ecoflow app? if so, do you have a timeline/ approximate date release. i would like to link it to my solar system to schedule charging. i also have powerstream. it would also be great if the powerstream had a programable sleep timer so that the delta pro and inverter could power off when not in use for prolonged periods. kind regards
I hope someone here can help me with the following and this is particularly about the bidirectional part of Homey working in the Ecoflow app. I recently bought a Ecoflow STREAM home battery. It is supposed to connect to the Homey Energy Dongle using the Ecoflow app. Instructions on for example ecoflow.nl are pretty straightforward. However, when I try to connect my energy dongle in this way, no devices are found by the Ecoflow app. I get a confirmation that my Homey account is linked, I get to select my Homey and give access to almost my entire Homey, but the energy dongle is not found in any way.
First things I already did:
turn on the local API setting in the advanced settings menu of the energy dongle (forgot that on the first try).
do a full hard reset on the energy dongle and reconnect it to Homey
Both options did not help. Is there anyone who would be able to help me in any way?
Since the integration of the Homey Energy Dongle within the EcoFlow app is developed and maintained by EcoFlow, it’s best to contact their support team. They’ll be able to assist you further.
On the Homey side, the integration uses our Cloud API. This means the LAN API on your Homey Energy Dongle does not need to be enabled for it to function.
Just a quick update from my side, since I’ve been testing a bit more.
It looks like the issue only happens when the Homey Energy Dongle is paired with a Homey Pro.
When I disconnect the dongle from my Pro, create a new Homey cloud-only account and add the dongle there, the EcoFlow app finds it instantly. In that setup my EcoFlow Stream Ultra X receives the P1/meter data without any problem. Unfortunately my Homey Pro is no longer connected to the energy dongle now.
So the dongle works with the Ecoflow App, but apparently only when it’s linked to Homey Cloud and not when it’s linked to a Homey Pro. That makes me think the EcoFlow app can’t detect the dongle properly in a Homey Pro setup.
Since most users will have a Homey Pro instead of cloud-only, this might be something EcoFlow and/or Homey should look into. Possibly there is an issue on the Homey side of this… possibly the Cloud API?
If anyone else can test this or has a solution, I’m very interested.
