Generic modbus app
Hello everybody,
Where could I find a generic Modbus apps to communicate with a Schneider iem meter ?
Tanks
You can find it by searching both the app stores:
Hello thanks but it’s not a generic, I would like to change the modbus holding or inputs registers.
I can only say, if your search phrase does not show the results you’d like to see, then most probably there isn’t an app for it (yet).
You could try to request for an app here.
Or build one yourself :wink: but idk your skills
Cheers
Looks like the Schneider IEM uses ModBus-RTU through RS485, thus you’ld need some type of ModBus converter / gateway to convert to ModBus/TCP. I doubt there’s anything that generic available on homey, but you never know. Do you have a list of registers?
Yes the meter is connected through a rs485/TCP IP gateway
The register is 3053 holding register float 32
Hey guys not even a bacnet IP app is available anybody knows?
is there already a generic modbus tcp app? It would be very helpful for different modbus devices.
not that i’m aware of. It would be nice if it could be added as flowcards (R/W/RW, addess, length and addres type). then you could create your owm virtual devices and link the data.
or something like the “capabilities” app, there you can define your own device. would be nice if there was something like that being able to also add modbus endpoints.
Hmm, seems stil no possibility to connect modbus TCP/ IP devices to homey. That is a little bit strange/ poor as Modbus is an old standard for HVAC devices.
I have the same problem, heatpump and photovtaic system communicate both woth modbus but no homey App.
Hi
There is already a fantastic app for modbus available.
