Garage door Thirdreality sensors to control lights help
So, I have two garage roll up doors, they have Thirdreality tilt sensors. I can make a flow to turn on a light when either door is opened, but how do I make a flow to turn off that light, when BOTH of the doors are closed? Connecting the two “door closed” when cards to an ALL card and then a light off command doesn’t work. I’m sure there’s a smart way to do this… These doors are controlled by a zwave wall switch.
WHEN
door A is closed Or
Door B is closed
AND
Door A is closed and
Door B is closed
THEN
Turn off light
So simple, yet I couldn’t see it before. This is perfect, thank you!
Another option if the garagedoor sensors are in zone ‘garage’.
Opening a door will make the zone active.
WHEN
zone ‘garage’ becomes active
THEN
turn on Lights
WHEN
zone ‘garage’ is inactive for 1 minute
THEN
turn off lights
Thanks for the second option! I implemented the first, and it worked perfect. I tried the second, and it didn’t work, so I went back to the first. Sorry I didn’t troubleshoot - thank you for sharing!
