As @Arnt_Soloy pointed out; the fan needs the key to create a bonded connection. Hence, it is not possible to integrate the fan directly with Homey. If you use Home Assistant parallell to Homey, it is however possible. I have set up Home Assistant on a Raspberry Pi 4B and managed to control at least the fan speed this way. Then I connected Home Assistant to Homey with the Home Assistant Community app. Pherhaps too large-scale for most users, but possible if you really want the fan to be controlled via Homey.
Maybe it would be good if many of us request this feature?
See the replay
”Hi Fredrik!
Thank you for your email!
At the moment, we have no plans for smart home integration, but we log all requests/suggestions. If many people request this in the future, we may look into it further.
(We do not have an open API at this time either.)
We wish you a very good day!”
I have manage to create an app that can fetch the auth code and also set the fan speed etc.
I has some bugs as the BLE signal form the Fan is week and instabile. It will connect most of the time if the Homey unit is close to the fan.
If someone wants to help with the development I would appreciate that as my time and knowledge is limited.
The app is in early stage and you should expect crashes and bugs.
Lets fix this together ![]()
Git repo:
Hi Mattias, is it still working well?
I have been using the app to control two Intellivent Sky fans since late January. The initial pairing can take quite a few tries, but you only have to do that once per fan. I will say it’s currently fairly stable, but be aware there are occasional fails in communications with the fan. It’s not worse than to click a couple of times to get settings changed. There is also another version of intellivent app being developed on GitHub.
Have you solved the instabile connections @Andre_Strann
I kind of gave up ![]()
@Mattias_Jagefeldt I have added some slight improvements, and it seems to work fine ish for me. However, I noticed quite pretty code in another repo from JYxfeldt so I paused any further efforts on my end until I see the end result of that version.
