Since a few days my flows no longer work which I use with the LOGICA App. Does anyone else have these problems too?
Logica is build-in, no app we download. Maybe show us the flow that doesn’t work anymore so we can check?
And what happens when u hit the test button?
Nothing! Previously, a green check mark was added to the lamps. Now nothing is added and the lights do not come on. No error message either.
And if you add the tag again and sav the flow? A while ago I had the same with some flows(not all) and adding the tag again solved the problem. Strange though.
I tried that. I also removed and rebuilt the entire flow
I notice some hickup with a logic based app as well.
i have a flow which calculates the relative angle of a xiaomi cube. based on this value the volume of my sonos connect amp will be set accordingly.
last week this worked perfect. yesterday i noticed that the volume didn’t change when i turned the cube. after tripple checking the flow (in test no green check as Gertjan stated) i removed some of the tags and placed the same tags back in place.
after that it worked again. but with some lag which wasn’t there earlier. it was a bit hit & miss.
Hi, I am really interested in the flows you describe. Would you mind sharing those flows that calculate the rotation of the cube and base sonos volume thereon? Many thanks!
Wat is nu de oplossing geworden?
Ik heb geen idee. Wel ben ik erachter dat de flow welke via de Desktop App worden aangemaakt meermaals problemen geven.
I have no idea. However, I am aware that the flow that is created via the Desktop App often causes problems.
