Hi. I’m new to Homey, coming from SmartThings. I’m looking for the best way to make a flow where my Philips Hue motion sensor will trigger a lamp to turn on and then shut off after 5 min automatically. It that possible in flow or do I really have to make it as an advanced flow? In SM it was standard in “Routine” (similar to a flow). Thanks
Just a tip for the future, use the search function on the forum. Found this in a few seconds😉
Take a look here for importable examples:
There is an easy way to control lamp on duration using 2 simple flows
First flow to turn lamp on simple flow that when motion sensor is triggered a specific lamp goes on
Second flow to keep lamp on for a Variable defined period of time.
Using the card for a specific lamp “Turned on for Sec on” in my case a variable that keeps the lamp on for 360sec whatever happens.
Do realize you revived a 2 year old thread with no additional open questions?
You should remove that link, it contains your Homey CloudID
