I have a Namron dimmer connected to some spotlights in my kitchen. However, in the kitchen, I also have several Philips Hue bulbs that I want to dim and turn on together with the spotlights. I’m not quite sure how to create a flow for this. Any tips?
So there is a zigbee dimmer connected to standard lights and if you dim to a certain level, you want to dim Hue to the exact dim-level?
When the dim level has changed (of the Namron dimmer)
Then change Hue light to dim level #level (use the tag in the flow).
