Flow 'than' card does not show state of logic yes/no variable
Is your variable of the type Yes/No ? Green logic is normally used for Number variables
Yes, it is a yes/no variable. And in this case the instruction is to set it to no (but that does not show :smiling_face_with_sunglasses:)
The position instruction shows that it has to be set to 100% (as it does an should)
I just made a test flow and see the same thing as in the image of the first post.
Strange, perhaps a bug ?
What version do you run?
Hi Hans,
Congrats, you’ve found a :cockroach: in the mobile (Android) app flow editor. Please report to homey.app/support.
(You’re probably using mobile app v10.1.x)
Mobile Android app v10.1.0.2047:
Web app:
As you can see, all 3 logic variable types are affected.
The same problem in the iOS app (v10.1.0.2047 TestFlight).
Hi Justin, Hi Peter,
I have the problem with both the Apple IOS app (v10.1.0) and with the Android app (v10.0.0)
Let’s see what support thinks of this.
Thanks for the verfigation gentlemen!
Grtz, Hans
Just to complete the list: I am using the iOS app with version 10.0.0.2028
To be sure I updated my app to the latest version 10.1.0.2047, but the problem is still there.
Final test: web interface (my.homey.app)
No problem, all information present!
Definitely a mobile app issue
I can confirm this is an issue in our mobile app, fixed in the next release. Thanks all for reporting.
