[Flow] Start flows at beginning of a period, last day of this period and last day + 1
I want to define a period of time (start date and end date) in only one card (easier to modify) like:
periodCard:
  • start date: 8h00 - 17/10/18
  • end date: 20h00 - 20/10/18
firstDayPeriodCard:
  • If motion sensor started then lights on
lastDayPeriodCard:
  • If doorlock is locked, no motion for 3 hours then lights off
+1DayPeriodCard:
  • If no motion for 10 hours then start cleaning
At this point, I’ve got something like this (with the help of Maikel):
But I don’t know how to trigger things at the end and end +1 of this period :frowning:
Any ideas for me ?
Have a nice evening !
Julien
Any ideas ? :grinning:
Yes.
Unpossible.
U can make flows with the trigger “This flow is started”.
Then u can make the flow like above and instead of “Enable a flow” u could use “Start a flow”
Then u have ur trigger.
Hello !
Thank You for feedbak !
Is it possible to calculate thé différence between two dates (in seconds) and use this as a delay to start a flow ? (I don’t know if I’m clear enough)
Enjoy your weekend !
Julien
3.5 days = 84 hours in seconds still 84 hours delay? What do you want to start delayed with 84h?
Pls describe what you want to accomplish for a scenario not the way you thought but didn’t finish.
Edit:
your Period Card is a condition, either date between or time between, but not date&time between other date&time. if you use both cards it will have impact it wont run any night.
If you want to enable / disable something over a long time you need two flows / two triggers each with a date/time one start to enable and one end to disable. or a schedule (2 x an alarm) or one of the 3rd party apps (maybe possible with Homedall? or… I don’t know.).
The enable/disable can be a Tag or Virtual Switch. (HouseIsRented = true)
Flow 1: Enable When Time (or an Alarm Start) , then HouseIsRented = true
Flow 2: Enable When Time (or an Alarm Stop) , then HouseIsRented = False,
Other Flow: When Motion detected, and HouseIsRented=True and between xxh - yyh, then Lights On and Start CountDown Light 3h and Start CountDown Cleaning 10h
Other Flow: if CountDown Light = 0 and Door is Locked, Lights Out, (? Why 2h59 after locking the door? but Ok.)
Other Flow if CountDown Light = 0 and HouseIsRented=False then Start Cleaning (this can trigger more often if there is motion, but add a counter to stop triggering if you want.)
This last one will not trigger if there is last motion more than 10 h before end period. but you can fix that…
Hey Dijker,
I’m searching the easiest way to start flows at the begining of a period, start flows at the end of that period and start flows at the end of the period + 1 day :slight_smile:
thank you,
Julien
Flows don’t run continuously, they start on an event.
That could be a change in a value (fe Temperature, energy, light), an alarm (Motion, fire, a set Alarm Time/Day) or an other state change (Presence) or at a certain time (a date, a time each day, sun up/down, every xx seconds/minutes/hours…)
There is no easy way to put your request in one flow at the moment.
The only way to trigger from the start of one flow on a 2nd and 3rd time is to start something (fe Countdown) that creates new events (CountDown Timer reaches 0 ) where other flows trigger on.
Thank you a lot for information Dijker !
07
I’ve done something like that and I’ve just to change ‘Date check-in’ and ‘Date check-out’ :slight_smile:
Maybe I’ll find a solution to trigger whit iCal directly !
Have a nice weekend,
Julien
