Flow on sensors
Can someone help me create a “Flow” :
If my water sensor / or one of my 3 pcs of fire sensors goes on alarm, then I want to turn on my Siren alarm.
Similarly, if my door sensor goes into alarm, I want after a time delay of 30 seconds Siren alarm.
Hi @toch,
There’re multiple ways to do this. My first suggestion would be to first create a group of your sensors with the group app. Which can be found here: < groep > | Homey
Create a group of your sensors
Then create a trigger that if the group sensor go in alarm you active your sirene
Another thing which would be good to explore is the heimdall app. Which is a very comprehensive security app with a lot of build in security and alarming features without you having to build to much flows
At the link below you can find more information on the configuration and features of that app
Or
  • Smoke / flood sensors:
    If…
    (select top level zone, ‘Home’ in my case, and then)
    An alarm turned on
    (Now pick a sensor type, f.i. smoke sensor or flood sensor.)
    Then…
    Turn on Siren
  • Door:
    • Flow1
      If…
      Sensor Door X Alarm turned on
      Then…
      Start or replace timer A 30s
    • Flow2
      If…
      Sensor Door X Alarm turned off
      Then…
      Stop Timer A
    • Flow3
      If…
      Timer A has finished
      And…
      Door X alarm is on
      Then…
      Turn on Siren
(I’m content with Chronograph as a timer app)
