Flow detecting a double click
Hi there,
I wanted to find some help with a flow I’m trying to create.
I have a qubino flush dimmers (ZMNHDD1) controlling the light from my house entrance.
I would like to create a flow to turn off all the light of the house when I double click the switch next to my door.
But I don’t have a card for the double click for this device…
Would it be possible to do it with another way?
Best regards,
Nicolas
Probably with the help of Logic. Make two yes/no variables in Logic, name: Click 1 and Click 2
Name: Flow 1, When qubino is clicked, and Logic variable Click 1 is not yes, Then set variable, Click 1 to yes, set variable Click 1 to no with a 5 sec delay
Name: Flow 2, When qubino is clicked, And Logic variable Click 1 is yes, Then set a variable, Click 2 to yes, start a flow Flow 3 with 1 sec delay, set variable Click 2 to no with a 5 sec del
Name flow 3, When this flow is started, AND variable, Click 1 is yes and variable Click 2 is yes Then turn off all the lights, else turn on the lights in the doorway
Thank you for your help, just tried this at home but unfortunately there is no card for detecting click nether.
Actually I have a card to detect the change of intensity level.
My light are not dimmable but I set the minimum value to 98% and the max value to 99.
With this I created a card : if the intensity is changed (that I do by pushing the button one second) then all light off.
It is working well even if the dim change by only 1%.
But now, if I switch to on or to off the entrance light with a simply touch of the button, it also turn off all the light…
What kind of logic could I do to prevent that?
Best regards,
Nicolas
I found how to to it, if this can help some readers :
So I created a numerical variable “ROOM” in logic = 1.
Then created a first flow : When intensity level is changed, and the light is ON, then define the variable ROOM to “power” of the qubino DIN. Start Flow 2 after 1 sec.
Then for the second flow : When this flow is started, and the variable ROOM = “power” of the qubino DIN, Then Stop all the lights and set variable ROOM to 1. Or set variable ROOM to 1.
There is a little delay when i hold the button to see all the light power off but that’s fine.
The only thing is if the entrence light is off, I first have to switch it to ON first.
it’s frustrating to see that the Qubino DIN don’t have a card to detect a click or a double click…
Is it not possible to create new cards ?
Best regard.
Nicolas
Use this post for questions to Qubino developers:
