Flow between dates
Is there a way to set the conditions for the “between dates” without setting the year?
Something like this?
May you mean this:
Thank you, unfortunately I can not translate the pictures to English to understand.
Thank you, unfortunately I can not translate the pictures to English to understand..
WHEN
every day at 0:00
AND
day is 30 and month is april
THEN
set YES/NO variable ‘heating season’ to NO
October 15th every year the variable is changed to YES
So when variable ‘heating season’ is YES the date must be between october 15th and april 30st.
So
WHEN
wim comes home
AND
THEN
turn on heating
The webapp advanced flow can be translated with your browser
@Wim_Post @Mark520
And with Google Lens app you can translate text on images
If Time = 07:00
And day is between x and x
And month is between x and x
Thank you this will do what i am looking for. If i want my lights to come on from Jan 15 to Feb 15 in a particular color i will just set the parameters for each month and connect the true false accordingly.
