Im trying to control my water heated flooring.
Currently I have received some tado thermostats, and want to incorporate them into Zwater2 (9 relays that can control 24v actuators)
Well, my problems is the setup of flow. If I run the test then the relay will shift, but not by it self…
I have tried both the “cards” from the tado it self, but also used a virtual device and used the tags from the tado (temperatur).
My setup is:
When= Temperatur is less “tag” (Set to tado wanted room temp)
And= Tado/Zwater is on
Then= Relay 1, switch to on (Z-water)
Any insights to what I’m doing wrong?
As it is not functioning as wanted.
