The Fibaro app does not update the temperature from the Z-wave Universal Sensor after May 21, 2026 05:00.I guess that’s when homey was updated to 13.2.0. The two separate outputs seem to work. If I restart the Fibaro app, the temperatures are updated once. Kind regards, Peter
Sorry! I ment the two separate INPUTS seem to work. Now i have to restart the Fibaro app every five minutes. Regards, Peter.
Hi Peter, I have the same issue. I have just submitted a request to Homey but I haven’t had a response when I have done this previously so not too hopeful. Have you made any progress?
Have you tried updating to latest release candidate v13.2.1-rc.4 ?
I have done the uppdate to release candidate v13.2.1-rc.4. And now it works. Thanks!
I have the same problem, have tested the latest beta and been in contact with Homey, unfortunately nothing I have tested works. (they were quick to respond)
I have also deleted and added the device (and lost all temp data
), I got 2 New repeaters Aeotec 7 but nothing works, the multisensor device forwards signals from other devices and I can change settings and save but Temp is not updated from my 4 temp sensors unfortunately.
If I repeitly restart Fibaro App 1 tempsensor ofter uppdate and 2 and 3 somtimes after multiple restarts but newer temp 4
Now after the latest update it says that one input is open even though nothing is connected, acknowledges if I change the normal mode to open or closed it still alarms that it is open.
I will see when I have time to throw together a new Multi sensor to test if the new one behaves the same way with new sensors and a new device that is closer to Homey Pro
I don’t think there is anything wrong with your universal sensor. After you have configured how you want your inputs NC or NO. I think you need to activate the inputs once to synchronize.
Now I have tested 3 different universal sensors and also built a new one with new DS18B20 none of them update temp or active switches, but they work as a router and settings can be changed, but no updates ever.
Got tired and bought Fibaro smart inplant instead and all sensors now update as usual, so I am replacing all universal sensors now because nothing I have tested has worked (remove, add, beta firmware moved sensors, get Range extenders ect, Homey/Fibaro is aware of the problem but I can’t wait any longer as I am dependent on the temp sensors.
i hope i can use the old universal sensors someday.
Now I’m tired of Fibaro universal sensor. Now it has stopped working again after the last Honey update. I use it in a critical application, armed alarm and activated alarm. Will replace Fibaro with a Shelly Uni smart implant
It works again, hurray! Thank you very much. Regards Peter
