Fibaro Single/double switch 2
With http-requests over tcp/ip you can do a lot… but it will cost you a lot of work…
As this was the question from the TS this conversation is going off-topic a long way. Plz keep it on-topic.
Posts not about connecting the Fibaro switches to Homey under my post will be deleted without further notice.
Just be aware before you spend to much time on this issue.
The Fibaro Double Switch 2 (FGS-223), won’t actually work correctly with Homey.
Currently they are not pairing in secure mode.
The S2 will not be updated with in Homey when it is toggled on/off
Also :
The S2 will not display its total power
The S2 will not display the current power.
I’ve been told by Athom that :
I can’t guarantee this will ever become the standard fix for this device
Can anyone tell me the difference between FGS-222 and FGS-223?
Need it to be potential free as hoping to modify a wireless remote…
Thanks
FGS-222 (Relays 2) potential free contacts.
FGS-223 (Switch 2) no potential free contacts but with measuring on the outputs (Watt & kWh) and with scene activation.
Further they are the same.
Thanks. Best find myself a 222 then!
Just an update on my last post from Feb, as apparently not everyone has been made aware. The S2 will now correctly show energy useage. (most of the time).
But it will require that you remove and re-add your dual switch if it is not working for you.
