Thank you Osorkon !
It works for putting a command on the right zone, but not for display the state and request on it. Great start but not fully usable.
I have tried to make a flow with each color state but there is only “voltage” and not dim level
If you use a virtual Dimmer, you can control the light and also display the current status.
For sure, if you control the light in an another way this doesn’t work.
Hello Cyril, did you find a solution?
I am trying anything but i am not able to get the starus of each channel to start the Flow. So the status of virtual dimmers is not correct.
In logic i see that the inputs never changes and i think thats the bug.
