Fibaro motion sensor + flow
This is not gonna work as you want probably: You cannot cancel the 2 minute delay. So when the motion is re-activated, it will still disable the light after the first motion-deactivation.
You will need a timer which you can cancel.
Take a look at this (importable) flow:
(When you import the flow with the Device Capabilitites App, all flowcards will be in your language or English/Default).
