Fibaro KEYFOB 2x,3x does not work
I have the same problem, it works only as default with 1 pressure or long press, going in the settings to change the pressures to 2x or 3x is not saved on the homey giving error
"settings could not be saved (Error: Timed out after 30000ms) ",
I tried in every way, even waking up the remote control before saving by pressing “circle” and “dash” but nothing at the same time !!!
Do any of you work with 2 or 3 pressures?
How did you do?
Thank you
Nobody has this problem?
Nope, keyfob works just perfect.
Great, so the keyfob works!
Would you be so kind as to help me solve my problem?
Are the steps I explained in the first post correct? Am I doing something wrong?
Thanks!!!
this is my problem, don’t save the change, how can I solve it?
thanks
Keyfob 2x,3x does not work
2x, 3x is disabled per default. You need to activate it in the settings after selecting the device.
It is disabled because it will seriously worsen the response time though, or so I have been told.
That being said, I have not been able to actually activate 2x, 3x, as the app crashes if I try… Hope this is fixed in the next major update.
My Keyfob has in addition stopped working. I can see it in Homey, and the green light flashes when I push a button, but nothing happens. I will have to look for a solution on that I guess…
