Fibaro Button - No difference in between the number of clicks
I have not upgraded to the 2.0 version yet. However I don’t think the problem relates to hardware faults. Definitively not when you got two of them. My problem with my Fibaro button is that it sends the different presses correctly (it can be seen in the developer Z-Wave log), but Homey doesn’t do anything with it. I have an open case with support where they acnowledge it as a problem in Homey.
They haven´t followed up the case since 6. december though, so customer services at Athom would definively not be rated as the quickest in the business regardless of a company doing a major upgrade or not. More manpower is just needed.
I would check the Z-Wave log to verify what commands Homey receives when you press the button x times. That is easy to trace. This is an example from my logs where I clicked once on the Fibaro button named internally as “Node[38]”. Look for the “Key Pressed x time” text for your spesific node:
[2018-12-01T14:46:29.064Z] Node[38]: Received application command for
COMMAND_CLASS_SECURITY, data: 0x40
[2018-12-01T14:46:29.064Z] Node[38]: [COMMAND_CLASS_SECURITY] {}
[SECURITY_NONCE_REPORT]
{“type”:“Buffer”,“data”:[98,0,55,152,189,7,204,171]}
[2018-12-01T14:46:29.065Z] Node[38]: sendData to COMMAND_CLASS_SECURITY,
params 0x8062003798bd07ccab
[2018-12-01T14:46:29.069Z] Command[223] start: sendData
[2018-12-01T14:46:29.070Z] ProcessSendData[209]: To node: 38 with data:
0x988062003798bd07ccab and txOptions: AUTO_ROUTE,EXPLORE
[2018-12-01T14:46:29.093Z] Command[223] end: sendData
[2018-12-01T14:46:29.115Z] Node[38]: Received application command for
0x81864515042973ccc3c1005ab9752d62bb4a1bd015f8fafa
[2018-12-01T14:46:29.116Z] Node[38]: [COMMAND_CLASS_SECURITY]
{“Initialization Vector
byte”:{“type”:“Buffer”,“data”:[134,69,21,4,41,115,204,195]},“Properties1
(Raw)”:{“type”:“Buffer”,“data”:[193]},“Properties1”:{“Sequence
Counter”:1,“Sequenced”:false,“Second Frame”:false},“Command
byte”:{“type”:“Buffer”,“data”:[0,90,185,117,45]},“Receivers nonce
Identifier (Raw)”:{“type”:“Buffer”,“data”:[98]},“Receivers nonce
Identifier”:98,“Message Authentication Code
byte”:{“type”:“Buffer”,“data”:[187,74,27,208,21,248,250,250]}}
[2018-12-01T14:46:29.129Z] Node[38]: [COMMAND_CLASS_CENTRAL_SCENE]
{“Sequence Number (Raw)”:{“type”:“Buffer”,“data”:[12]},“Sequence
Number”:12,“Properties1
(Raw)”:{“type”:“Buffer”,“data”:[128]},“Properties1”:{“Slow
Refresh”:true,“Key Attributes”:“Key Pressed 1 time”},“Scene Number
(Raw)”:{“type”:“Buffer”,“data”:[1]},“Scene Number”:1}
[2018-12-01T14:46:29.129Z] Node[38]: Decapsulated frame from
COMMAND_CLASS_SECURITY to COMMAND_CLASS_CENTRAL_SCENE, data 0x030c8001
