ESPhome app including Haier (hOn based) AC Airconditioning
Hi All,
It has been a long time since I was last active here. In the early stages of homey I created some apps for z-wave devices. But along the way, I got other priorities.
Now I am biting into a new thing.
I have a Haier AC. There is no Haier app available yet.
The wifi module is connected through USB and therefor easily replaced. The Haier ac’s consist of 2 types:
  • Based on hOn
  • Based on SmartAir
There is a piece of software called “ESPhome” that can be installed on a Wemos D1 mini.
And can than be controlled by Home Assistent. But i don’t have that, i have a Homey ofcourse :smiley:
Someone created a piece of ESPhome software which should connect the Haier hOn AC to Home assistent: https://github.com/paveldn/haier-esphome
But I dont want to control my AC with Home assistent (for I don’t have that), I want to control my AC with my Homey.
Fortunately, someone has started developping a Homey app for ESPhome devices.
(which is than applied to the appstore by someone else without asking the developer!)
https://github.com/Inversion-NL/Homey-ESPhome
So now my plan is to add the ESPhome device for Haier AC into that app.
https://github.com/priknr1/Homey-ESPhome
But, my programming skills for homey are quite rusty. I added a new device, and the app is compiling.
I can fill in the IP and port for the ESPhome device, and it starts to communicate.
But then I get the following error 7 times before a timout occurs:
2023-04-14 18:11:38 [ManagerDrivers] [Driver:esphome-haier_ac] Error on device 192.168.1.119: TypeError: Cannot read property ‘deserializeBinary’ of undefined
at deserialize (/node_modules/esphome-native-api/lib/utils/messages.js:90:52)
at Socket. (/node_modules/esphome-native-api/lib/connection.js:26:34)
at Socket.emit (events.js:311:20)
at addChunk (_stream_readable.js:294:12)
at readableAddChunk (_stream_readable.js:275:11)
at Socket.Readable.push (_stream_readable.js:209:10)
at TCP.onStreamRead (internal/stream_base_commons.js:186:23)
Is this 7 times the same error on a retry, or 7 different errors?
What could cause this error?
Does it maybe have to do with unknown capibily names?
Baldhor has picked up the development of my app.
With my permission, this time. In contrary to the other app which was in the app store and is now replaced.
Could you post the output of the device which is logged at line 34 in the driver.js here:
https://github.com/Baldhor/Homey-ESPhome-Enhanced/blob/main/drivers/esphome-device/driver.js#L34
Turns out the issue was in my Wemos board with the AC, not my connection from ESPhome to the wemos board.
I was able to connect and control my Haier Airco from homey now.
If anyone wants to do this, below is a summary of the steps.
  • Buy a Wemos D1 Mini (ESP PCB for a few euros)
  • Provide this with ESPhome firmware with settings for the Haier (for details see:
    GitHub - paveldn/haier-esphome at experimental)
  • Make a connection for 5V, Gnd, Rx and Tx. (Details also in previous link)
  • Remove any original WiFi module from the Haier Air Conditioner and install the Wemos module
  • Install the ESPhome app on Homey
  • Add the air conditioning to “Hardware devices” via the ESPhome app
  • Add the air conditioning to “Virtual devices” via the ESPhome app
  • Link the desired functions of the Hardware Device to the Virtual device
Hello priknr1,
I would like to get my haier ac in the homey app. Can you sell programmed wemos d1 mini devices with the right firmware already installed?
best regards,
Problem with that is, it needs the WIFI SSID and Password in it, and I am not familiar enough with programming the wemos in a way that it would become Accesppoint where you could fill in the Credentials for your wifi yourself etc.
That indeed is a problem. Thanks for thinking with me!
When it can’t connect to your wifi, it should turn on AP mode.
When you can’t find a wifi SSID to connect to, or when it just won’t connect:
You can view and edit the yaml by connecting the board with a USB cable to a pc/laptop
App for Haier airco
