Hello.
Is it just me or is there a bug in the software now?
I used to go to devices and rhen flows (in the bottom.) and then be avle to edit the flow that was linked to that device.
Now i can not, so i need to wrigth down what flow this is and then go to flows and search for the flow..
No that feature is still there. I have seen in the past the Homey app on my iPhone get into a weird state where that icon does not show. Force quitting and restarting the app fixed the issue for me. I’ve only seen it a few times so not sure what the cause is.
Hello @Kallemann ,
there are some issues, that might be improved, but are no errors.
- On the web version, you don’t even have a list of flows. So there is no chance of editing them just by click. But you also have no chance to write the flow name down. You have the list in the app for android (and probably IOS)
- In the Android app you get a list of flows and at least I can open and edit them by clicking on them - if they are standard flows. I have to tell that I still use version 12.3.0 of homey pro 23 firmware.
- The Android app cannot (yet) edit advanced flows, so when you want to edit an advanced flow, you see it in the list of flows on android but you have to edit it in the web interface. So you have to write it down and look for it later in the flow area.
Probably your case is different, so pleas tell us exactly where is the issue. In the best case you provide one or several screen shots.
My mobile app version on iOS/iPadOS is 9.2.5. I am also not able to edit flows via the devices flow tab. I wasn’t even aware that that was possible in the past
. I normally use the main Flows section to edit Standard Flows, which is still possible in this app version.
Suggest you report this to Athom via Support | Homey.
Thats not true, you can right click on any device, then there is an option to filter for said device in all flows (the “flow” option in the context menu)
Thanks @Caseda ,
yes I even saw this and forgot it again.
Unfortunately the procedure is totally different from the one on a smartphone app.
But it is good to know that we can do it that way.
regards Dirk
