Downgrade Firware Early 2023
hello my name is Kit,
love the homey pro, everything work great untill yesterday firmware update to V12.2.0
12 of my motion sensor stop working. aqara FP2 connect with homekit app.
I also tried uninstall and reinstall homekit app. still not work.
Could you help me downgrade to stable V12.1.2 please.
I tried local backup with USB and factory reset it still stuck on V12.2.0
I also tried these step but I can’t get homey pro to show SSID
if I can get homey pro to show SSID I belive I can downgrade with setup.athom.com
1.Checked in homey developer that experimental tab ticked off
2.Checked in Homey app that all experimental ticks are off and ticked of automatic update.
3. Chrome web browser open setup.athom.com , proced until when need to connect to Homey setup SSID
4.Turned homey upp and down, count from 10-0 , connected to Homey setup SSID.
5.Now i made choice of Dont connect an athom account with ALT button option.
please help
Thank you
Hello Kit,
It’s possible when you have an USB offline backup of Homey running v12.1.2
I’d recommend to make an offline USB backup prior to updating firmware.
Or when Homey runs a RC version of v12.2.0:
Steps to revert from v12.2.0-rc.X to v12.1.2:
I just want to inform you this is veeeeery old information, also it was only for Pro 2016-2019 series, but even that has changed.
At the support pages, enter 2023 along with your search phrase to get actual info.
As example:
So to enter a Pro 2023 setup, just press the pin at the bottom for 9s, and go to https://support.homey.app/hc/en-us/articles/7263435817116-Connecting-Homey-Pro-Early-2023-to-a-PC-or-Mac-with-USB
But you don’t need anything with SSID here.
I do hope you inform the developer of the Homekit Controller app as well, by posting your issue here:
Support links like that can be found at the homey.app store app pages.
12.2.0 is supported through the test version. Just read the appropriate topic concerning the app
Thank you so much for your respond.
but sadly my local backup is V12.2.0.
there is no other way?
Thank you so much the test version is work.
life saver!!! everything working now.
Thank you thank you thank you
