Does Homey have a capability for Volatile Organic Compounds (VOCs)
I am playing with a CCS811 gas sensor (cjmcu-811) and can’t seem to find a capability for VOCs?
Are there any other alternatives for registration?
Hi Marlon,
Your post has been moved to ‘developers’ as this is the most likely place you will get an answer about adding device capabilities.
You can see the full list of capabilities here :
https://developer.athom.com/docs/apps/tutorial-Drivers-Reference.html
Or you can checkout creating your own capabilities here :
https://developer.athom.com/docs/apps/tutorial-Drivers-Capabilities.html
It did take a while but I found it. The capability is called PM2.5 “Atmosperic particulate matter” and can be set using “measure_pm25”
Those aren’t the same, though: PM2.5 applies to very fine dust(-ish) particles, whereas VOC applies to organic chemicals (things like solvents).
Ok thanks for the info.
There’s this new sensor that has
Air pollution detector (TVOC, CO2)
Perhaps someone would write an app to support it.
Does anyone have the microbot?
Any experience?
The website states it supports google, alexa and ifttt. So homey should be able to get the data
But their shop is closed, it is sold out on Amazon and the reviews says they cannot get in touch with the company?
If you want to measure VOC and don’t want to build your own sensor (Homeyduino BME 680 BSEC library) at least awair and airthings have sensors which are supported in Homey. However they’re not as small as the microbot, and they don’t measure lux and sound.
A friend of mine bought the microbot, but it was not any good, most of the measurements were off. Just look for another one.
