Disable switch input Fibaro double relay KIDS Protection
Hy guys. I have one question and I will be grateful you if you can give me an idea​:light_bulb: :folded_hands::blush:
There is a way to “block” the input of the Fibaro double switch relay? More exactly, I want to block the switch input from my kid after 22:00, in that way he cannot turn on the light for more then 15 minutes, and after this, to block the input completely for 4 hours for Ex. The switch is mounted in the wall of course. In the flow i didn’t find anything like “Block” , “Freeze”, “STOP”..
Is the light connected and controlled by the fibaro derectly?
Or is the light a seperate smart bulb triggered by the fibaro switch via flows?
In the 2nd case the you can handle it in your flows…
In the 1st case… thr 2nd case might be a solution :rofl:
Hy FKey :grinning_face:
He presses the Switch from the wall, which is wired connected to the switch relay module (like regular cases). But I want to disable the functionality according to the scenario. With the flows, you are right, can be done using some conditions, but I dont use any wireless connected button.
So you are talking about the Double Relay Switch (FGS-222)? Or about the Double Switch 2 (FGS-223)?
I haven’t heard of this feature before, and I can’t find any relevant information in the linked manuals.
What parameter is used for this function?
I believe is FGS-222 model. Where I can see the parameter? :slight_smile:
To believe is not to know… :wink:
To find out the device type, open Developer Tools (link), log in with your credentials, select the Devices category and search for your device:
Then check the manual I linked earlier in my post to find out which parameter you are talking about.
If we know the parameter, then it may be possible to send a raw command with a flow to activate/deactivate the kids protection.
Dear DirkG,
Sorry for late reply and Thanks for your ideas :slight_smile: . Can you please tell me how to do it?
So, I just want to disable the ON OFF input from the Switch after 10:00PM in order to avoid my son to turn on the light (it`s sleeping time :slight_smile: ) Thanks Man
As I already mentioned:
So please answer my question and then I may be able to help you.
If you don’t know which parameter needs to be configured and how, you might want to ask Fibaro.
