I apologize for this inquiry. I am a beginner and I need advice. You can stop the flow of multiple cards in the same directory at once or each card separately. If there are more, it is tedious.
Thank you
If you need a killswitch you could possibly add a boolean logic variable to your AND section.
Am using this strategy to disable automatic light control for example.
