Dimmed lights wont un-dimm
I have two simple flows that turns on my Philips hue bulps when there i s motion on a Hue sensor.
I have set a condition that says that when the time is between 23 and 06 the light shall be turned on at 20%.
And it works fine - BUT when the time is after 06 in the morning the lights still go on at 20%. I can then in the app turn up the lights and then it will work the rest of the day.
i have tried adding a card that set the light to 100% in my “day time” flow but then the light goes on at 100% and then dims to 20% at night.
How do i set it up so that the lights not is dimmed between 06 and 23 but stille is dimmed to 20% between 23-06 ?
yes i do.
so on the night flow i only use dimm to 20% ?
Correct
Hi
i have tried using the dim card alone, but the light are still dimmed in the morning.
And i manually have to rise the light strenght.
One flow should be enough for this.
WHEN
Motion sensor activates
AND
THEN
Dim to 20%
ELSE
Dim to 100%
Great aeonax that worked like a charm.
Thanks.
