Dim-Level not working on IKEA TRADFRI
I’m using IKEA TRADFRI bulb E27 WS opal 980lm in a flow and besides changing the color I try to set the Dim-level with a duration, but the dimming doesn’t work with that. When I remove the duration of the dim-command and I run the flow several times after a while bulbes are making the dim change then.
My Homey bridge is only 3 meters away from the lamp.
What did I do wrong? Thanks for your ideas.
Regards Sebastian
If you share youre flow then there is maybe someone over here that can take a look at it.
This is the flow. The color change works, but not the change of the dim-level to 60%. It stays the same leven like before (85%)
Add a one second delay to the “Dim to” action cards in the “Then…” section. The commands are actually sent at the same time, so it’s possible that not all commands are sent correctly. Sadly this is also sometimes the case with the Homey Pro.
Thanks Fantross!
I was hoping, Homey is managing those “technical” delays in its internal command processing queue. This shouldn’t be the frontend users issue…
You’re absolutely right!
