I have a Digoo XYA doorbell which has a wireless ring that you can connect to it , it works with 433mhz.
Is there any way to connect this to Homey?
https://apps.athom.com/app/com.dondorp.homey.byronsx
You can try this. Worked for me with a other brand doorbell
Tried, didnāt work.
Klikaanklikuit also didnāt
I could if i know how. App itself should be doable. itās only the 433mhz code that i have to study then, which i donāt have the time for. I can record the signal however.
Action app maybe?
Iāll have a look at it when i have the time. Probably just clone the byron sx App and put in the correct Signal code should do
