Delay in setting 'Home' or 'Away'
I have some flows that use the ‘nobody home’ condition to send push notifications. They work well, based on ‘last person left’, and ‘first person comes home’. To test those flows, I set my own - and my wife’s - presence to ‘Away’ or ‘Home’ manually. I wonder if - and if so, after how much delay - these statuses change back (automatically) to their ‘correct’ status. I mean, without both of us having to leave and re-enter the geofence zone to trigger our presence. I expect the app to check periodically and reset to the correct status, but that doesn’t seem to happen? Of course, both our apps are kept logged on and active, and it still doesn’t happen?
Then I suppose you’ll have to adjust your expectations :laughing:
it seems logical to me, the status changes when a activity occurs, ie you or your wife leave the house or come home, no activity is no change of status.
Triggers in flows work similar: ‘If temp becomes higher than X’ trigger doesn’t do anything when temp already is higher than X and rises even more…
“You can’t come home if you’re allready home”
