I have a flow that turns on the lights when a motion sensor detects motion. The flow works, but I notice that there is a delay between the start and the actual trigger of the flow. That’s why I turned on Simple Log to check if my assumptions are correct. That seems to be the case, because in the log file I see the same delay of about six seconds between the condition and the actual action. This is strange because I don’t have any delays in the flow or what so ever. Do you have any idea what might explain this?
Part of the flow that triggers:
Example of the delays 1:
- 12-9-2023 00:26:03; Action; A1: Executed
- 12-9-2023 00:25:57; Condition; C13: true
- 12-9-2023 00:25:57; Condition; C3: false
- 12-9-2023 00:25:57; Condition; C6: false
- 12-9-2023 00:25:57; Condition; C7: false
- 12-9-2023 00:25:57; Condition; C5: true
- 12-9-2023 00:25:57; Condition; C16: false
- 12-9-2023 00:25:57; Condition; C17: true
- 12-9-2023 00:25:57; Condition; C4: true
- 12-9-2023 00:25:57; Condition; C1: true
- 12-9-2023 00:25:57; Trigger; T1: Triggered
Example of the delays 2:
- 2023-09-12 00:57:39; Action; A4: Executed
- 2023-09-12 00:57:33; Condition; C3: false
- 2023-09-12 00:57:33; Condition; C6: false
- 2023-09-12 00:57:33; Condition; C4: false
- 2023-09-12 00:57:33; Condition; C5: true
- 2023-09-12 00:57:33; Condition; C16: false
- 2023-09-12 00:57:33; Condition; C17: true
- 2023-09-12 00:57:33; Condition; C1: true
- 2023-09-12 00:57:33; Trigger; T1: Triggered
