Control Naim Uniti or Naim Mu-so via IP command flows
Naim is a British manufacturer of HiFi equipment that has released mid-end and high-end all-in-one streamers in their Mu-so and Uniti (Atom, Star and Nova) lines.
As far as I know, there is no public release of the API for IP/http control of the Naim units.
Since there is a Naim iOS/Android app available, I figured that it should be possible to reverse engineer the IP commands to control Naim all-in-ones with Homey. With some trial and error, I managed to extract some basic commands to control the Naim units via Homey flows.
First, get your local IP address of your Naim device. The port used by Naim for http-requests is: 15081.
You can make flows using logic:
The following specific IP commands can be used:
Power on send a PUT request to:
http://[Naim IP]:15081/power?system=on
Power standby send a PUT request to:
http://[Naim IP]:15081/power?system=lona
Set source/input send a GET request to:
http://[Naim IP]:15081/inputs/ana1?cmd=select
ana1 = analog source #1
ana2 = analog source #2
dig1 = digital source #1
dig2 = digital source #2
Etc.
Play send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=play
Pause send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=pause
Stop send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=stop
Mute volume send a PUT request to:
http://[Naim IP]:15081/levels/room?mute=1
Unmute volume send a PUT request to:
http://[Naim IP]:15081/levels/room?mute=0
Set volume to a specific value (“25” in this example) send a PUT request to:
http://[Naim IP]:15081/levels/room?volume=25
edit 08/2025: updated startpost with new commands for overview
Toggle Play/Pause send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=playpause
Next Track send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=next
Previous Track send a GET request to:
http://[Naim IP]:15081/nowplaying?cmd=prev
Start playing a streaming service or the play queue send a GET request to:
http://[Naim IP]:15081/inputs/spotify?cmd=play
available streams (replace “spotify” in the commandline above):
-spotify
-tidal
-qobuz
-playqueue (start the playing queue)
Play a favourite or preset send a GET request to: http://[Naim.ip.address]:15081/favourites/[code]?cmd=play
In order to retrieve the unique codes per favourite/preset: read these instructions
There is a volumeIncrease command, but so far I could not get this to work. Any help/suggestions to get this to work would be appreciated.
A few extra commands:
As a temporary workaround for volume control, the following strategy can be used:
  • install the Naim Uniti / Mu-So unit as a Chromecast device in Homey.
  • use the Chromecast flow chart ‘Set relative volume to [%]’. 1% increases the current volume by 1.
Hi @zigvespa , dont know maybe this helps? The author makes this for my Neeo Remote. meta-naim/naim.json at main · jac459/meta-naim · GitHub
Thanks, I’ve searched quite some Github codes to discover commands to control Naim units (in case anyone is wondering, Uniti units use Zigbee on the remotes, not IR).
Hadn’t seen this particular one yet. The direct IP commands I had already discovered.
Not really sure how to translate these volume up/down command lines to code that I can feed Homey through logic or any other type of flow. Anyone able to help?
"VOLUME UP": {
                "label": "",
                "type": "static",
                "command": "",
                "evalwrite": [
                        "variable": "VolumePlayed",
                        "value": "DYNAMIK (Number($VolumePlayed)<100)?Number($VolumePlayed)+1:100"
                "evaldo": [
                        "test": true,
                        "then": "__VOLUMESET",
                        "or": ""
            "VOLUME DOWN": {
                "label": "",
                "type": "static",
                "command": "",
                "evalwrite": [
                        "value": "DYNAMIK (Number($VolumePlayed)>0)?Number($VolumePlayed)-1:0"
                "evaldo": [
                        "test": true,
                        "or": ""
Is it possible to select the presets on my Mu-So ?
The commands listed above are the only ones I have discovered so far. Unfortunately, there is no public API/documentation by Naim.
I assume you do not mean your input sources when you mention ‘presets’?
on the dial of my Mu-so qb 2 are 5 presets, numbered 1-5. Sorry for the dust ; )
Sending http commands to presets or favourites on a Naim Uniti or MuSo is possible - but it takes some extra steps. Every favourite has a unique code. You first have to retrieve this code by sending the following command to your Naim in a console app:
GET http://[Naim.ip.address]:15081/favourites?
In the console app (you can use any app you like as long as you can see the results returned - I use the app Teste on iOS) you will get a response that displays all the codes. In this example, my playlist called “Old Skool” has the unique id marked in yellow:
In order to directly play that favourite, you need to create the following GET command:
GET http://[Naim.ip.address]:15081/favourites/[code]?cmd=play
In my example, to directly play the favourite playlist “Old Skool” this would be:
Hope this helps.
It all works I programmed al 5 presets ; ) Thanks for your help!
