Good morning,
I just installed a Homey at home, so I’m finding out.
I am looking to measure the consumption of a machine with a Fibaro Wall Plug Z-wave socket
I would like when it is turned on to increment a variable to measure its consumption, I cannot find my way to do it. So at any time I can know its total consumption
Do you have a lead?
Thanks in advance
Install the Power by the Hour app for this.
This example flow might come in handy as well (and you can import it !):
Gas usage calculation
Note: other gas using devices during the measurements aren’t taken into account
When you want to record the gas usage of say, a pump, for this day. Extendable by adding the day variables for week and month overviews
[Screenshot from 2022-11-28 21-52-06]
Output:
[Screenshot from 2022-11-28 22-02-09]
And it’s also available in Insights
Other things people need to do to get it working correct?
Select your own P1 gasmeter and pump On/Off indicator
TEF:
( imp…
Hint: please mention in your post you posted the same Q in an other topic as well:
Bonjour,
Je viens d’installer un Homey à la maison, je découvre donc.
Je cherche à mesurer la consommation d’une machine avec une prise fibaro Wall Plug Z-wave
J’aimerais que lorsqu’elle est allumée incrémenter une variable pour mesurer sa consommation, je n’arrive pas à trouver le mon moyen de le faire. Ainsi à chaque moment je peux connaitre sa consommation totale
Avez-vous une piste ?
Merci d’avance
Thank you for this answer and the indication of the app. This is indeed a good solution!
On the other hand, we have a bi-hourly meter with different night and day rates. I don’t have the impression that the app can make a distinction?
Yes you can set different rates by flows.
I’ve also a meter with high and normal rates, and I saved the actual prices in variables, which are used in the tariff entry of the flowcard
Thanks for the reply.
I don’t see how to set up different rates and schedules.
In the virtual device settings, there is no such possibility.
Can you give me an example ?
Thank you
