Ok, we now can install the Danfoss Icon 2 with Homey pro. Danfoss living connect is also intergrated with Homey,
How can I use these together, regulating the heat in my bathroom without using a Danfoss main controller?
Ok, guess the Danfoss Living actuator uses the roomtemperature in the room it is installed in, and that may be very different from the floor and roomtemperature in the bathroom. Then I guess I need to create a flow, saying when the Icon 2 measure temperature going under 20 in the floor, the Danfoss connect will be set to 28 C, This will then open the flow, and warm water will fill the bathroom floor. Then make a new flow saying, if Icon 2 discover that the temperature rises over f.i. 22 C, Danfoss living will be set to f.i 4 degrees, shutting of the the water flow.
Have anyone tried this, or something simular? Can anyone help me setting up the right flow? That would be mostly appreciated ![]()
