I want to measure if there is water flowing in my water supply pipes (both cold as hot). I do not need to know how much just if its flowing or not.
I do not want to change any of the piping so I want to be able to clamp it on a pipe and connect it to a Shelly Uni Plus.
Does anyone of you know where I can find this or maybe build it yourself? Most likely it has to be done with some kind of ultrasonic solution.
Thanks.
PS: I use the word “flowing” because it is impossible to use the word “flow”
DirkG
December 15, 2024, 11:44am
2
Found this really cheap (!!!) Digital Ultrasonic Flowmeter Module at Ali. But I don’t know if it’s possible to use it in combination with the Shelly One Plus. I guess you mean the Shelly Plus Uni , aren’t you?
This uses a clamp and uses ultrasonic measuring. But it’s not available yet
And, it does measuring next to flow detection
https://www.kickstarter.com/projects/aquaro-water-monitor/aquaro-smart-water-monitor-get-leak-alerts
Fantastic (unofficially official ) news, except of Home Assistant, also Homey integration will be included ! (or at least Aquaro is keen on getting to support in place thanks to interest of you - Homey users !)
