(Christmas) Light switch
I created a flow to control my Christmas lights and wanted to share it with you.
It basically triggers every minute and checks if the conditions to switch on are met.
https://homey.app/f/DRNICW
Why are you checking every minute??
I myself like to switch the lights on when it is getting dark in the living room. Therefore i use the lux measurements of a sensor. Also i have a 1 hour timer. This timer is activated by my indoor sensors. That way the lights only burn when someone is at home
The interval is not limited to 1 minute
However Homey flow triggers are very limited and that was the trigger that suited the solution.
That way I only need one flow.
In my opinion it would be better to create 6 flows (max, if you separate them all, you can combine the first 2) that run 6x a day, instead of 1 flow that will run 1440x a day!
Exactly, this flow is not “clean”, there is a problem with the “WHEN”. Absalon should create at least 3 flows, for example with the “Sun Events” app in the “WHEN”.
