Check if zone has been inactive for more than X minutes
Anyone know if there’s an option to check how long a zone has been inactive for? There are several use-cases for me.
I have some flows that will turn on all lights (by design). There’s no way to check if the zone was active in the last X minutes in order to limit some of the zones.
One would think it would be fairly easy to add an “AND zone has been inactive for > x minutes” flowcard :thinking:
Yes, there are WHEN cards already for the zones.
When there is no card that realizes your use case at once, you will have to do some more programming. When you describe your use case a little more, we can think about a solution, which might be quite easy.
For example: when zone has been inactive for 15 minutes set variable to yes. And then test this variable.
Or you check if a lamp in zone is on.
Not as “and”-cards. I cannot use the “when”-cards for this.
Hmmm…so basically set up variables for each zone and trigger a flow for every 5 minutes of inactivity up 'til 30 minutes or so, and then do a logic comparison? Hmmm…Interesting solution :slight_smile:
Or setup separate timers for each zone, that starts when becoming inactive.
Then use timer values for comparison.
Could the app I recently launched be of any solution to you? It adds the condition (AND) flow card “The zone… has been inactive for at least 10 minutes.”
@Erikvl87 , really high hopes of your app. Hope it functions as intended, as the Homey-built-in-functions does not. Maybe you can make a support topic for the app in this forum?
@Marius_Stensrod Thank you for setting such a high bar! I hope my app will meet your expectations. I do plan to set up a support topic for the app soon, but right now, my focus is on the GitHub repository. Balancing my time has become crucial, especially since I recently became a father, so managing support in one place (GitHub) is more practical for me. If you have any requests or suggestions, please reach out via an issue at Erikvl87/nl.erikvl87.zoneactivity: Enhance your Homey flows by adding conditions based on zone (in)activity. (github.com)
@Erikvl87 , first of all, congratulations! I understand the time issue. Then GitHub is good enough. I will test your app and report issues at GitHub :ok_hand:
If my topology of my rooms is like the image I would expect that activity of 'slaapkamer’also depends on badkamer because it’s a subroom. But I think it is not because it does not work in Flows. Anybody comments about this.
And if so how to use in a flow when als the rooms are inactive for 15 minutes ?
This is the only solution I think to do this but very nonlogical
