Chart unavailable
For many reasons a device may removed. Later going over some flows, you find a flow that shows " chart unavalaible", but no clue what device was used. Why is there no way to easily find the device that was used in the particular flow?
You’d ask Athom: homey.app/support
Ways to workaround it:
  1. Before removing a device, you can check in which flows it’s used. Not 100% accurate though (flows with logic cards holding the devices’ tag aren’t detected).
Or
2. Install Flow Checker app, then
    1. First disable the app of the device
    1. Flow checker reports the breaking flows
    1. Screenshot the broken flow list
    1. Enable the app of the device again
    1. Screenshot the devices’ cards, make sure to store them in a folder with the flow’s name
Or
3. Just restore a backup to see what cards it actually were
I make and update screenshots of the flows to just put things back when needed.
