Change Sonos Set Volume to a value instead of a slider
In the Sonos app there’s an option of Set Volume, where you can set the volume with a slider.
If it was an input value field instead you’d be able to you tags or transitions as input.
Who says this is not possible? :grin:
The use of tags (pulling the tag over the slider) is possible; just search for Sonos and volume on this forum.
Also the transitions app topic shows an flow example creating a volume transition to fade in and out the Sonos volume.
I must admit I’m rather new at this.
But I’ve tried dragging a tag to the slider, and nothing seems to happen.
And where do you see the Sonos example?
I can’t see it on https://apps.athom.com/app/name.klep.transitions
Hi again
I found it (Transitions — Flexible time transitions), it helps when I read what you actually wrote.
I managed to get it to work, it’s just very tricky to get the tag to be accepted by the slider - the Homey apps seem a little finicky about that.
Just use the Chrome browser and ignore the warning.
I didn’t know you could do that.
But after trying it, I find that it’s just as finicky.
