Can not install the new Onkyo app, messange No response from IP adress. The receiver TX-NR414 is connexted to the homenetwork via powerlan.
You can’t install the app, or you can’t add the device? Two different things.
Correct, I can’t install the device. The app is allready installed
Hi Jan. Is your onkyo receiver tx nr414 connected with Homey? Have you solved this issue?
