Calculate time variable
Hello dear community
I have another question for you - you are always such a wonderful help - so thank you very much :slight_smile:
in homey flows you have access to the current time as a system variable. I would like to have a push notification sent in which the current time is added by e.g. 90 minutes (so if the flow is triggered at 2 p.m. (german time 14:00) , for example, the notification should display 3:30 p.m. (german time 15:30), for example. It might get tricky here at 11 p.m. (23:00) , for example. This would be the result then 12:30 a.m. (00:30)
how can i calculate the variables? So for example: “Time_Notification” = “Time” (system variable") + 01:30 or something like that - by logic or by homeyscript? thanks for further help - screenshots are always helpful otherwise :wink:
thank you very much
Maybe this can be of help
and / or
Better Logic Library is a really powerful tool for stuff like this.
thank you for your information about it.
I installed the app - but now I need the code for the calculation. I also put it in the app thread. can you maybe help me here?
[APP][Pro] Better Logic Library - For Users (Homey Community)
Thank you :slight_smile:
