Calculate duration
I’m trying to calculate the duration of the time my pool pump needs to run, based on the water temperature.
The flow itself works, when trying an easier formula {{(temperatuur/2)*3600}} for example, then it works.
But the formula i’m trying to set is {{((Temperatuur/2)-(0,2 *Temperatuur))*3600}}
However, i’m not getting any value stored in my variable.
It’s probably a syntax error, but i can’t figure out which one.
Suppose it is . Instead off ,
So {{((Temperatuur/2)-(0.2 *Temperatuur))*3600}} will do the trick
Thanks that worked!
Could you share your flow?
https://homey.app/f/G80Qnh
