Buienradar Forecast widget doesn't load
Hi All,
I’m trying Dashboards on my Homey Pro (early 2019), and specifically the Buienradar-app. I’ve installed Buienradar v4.1.3 and trying to add the Forecast-widget to my dashboard. The thing is, I’m able to add the widget, but it keeps loading. I’ve restarted my phone, restarted my Homey Pro, reinstalled the Buienradar-app, but Forecast won’t load any data. The other widget from Buienradar ‘Map of The Netherlands’ does load without a problem. Any suggestions?
Because it’s an Athom widget, you should write to homey.app/support, like mentioned @ the app store buienradar app page.
In the Dashboard mega thread you’ll find alternative weather maps, which use the Web widget. Like this one:
( Thanks to @Rogier_Verheugen )
Thanx for your reply. I’m able to add ‘weerplaza.nl’ as a web widget but, it doesn’t refresh. I now have a loop from 14:35-15:35 (local time is now about 17:20…). Any suggestions Peter??
Hmm, mine just started with 17:30
Did you enable “autorefresh” setting? You can set it to 900s for example.
Okay I’ll test this. Yoy also enabled ’ scrolling?
One other thing, it’s showing the ‘past’ hour (or so). Is it possible to let it show prediction for +2/+3 hours?
Here’s the cofiguration possibilities:
And I enabled scrolling.
