Any visualy pleasing weather forecast widgets?
Hi, I am looking for any good looking weather widgets that would use my weather station data. It can be eather app or website which I will add as URL into my dashboards.
I already use WUnderground but the widget that comes with the app is not the prettiest. I have also used the default weather widget but I don’t know where does data comes from.
You may play around with this widget maker from Openweather, 1000 free api calls a day
What would you like displayed?
I’m happy to take suggestions for the weather underground widget.
Although it’s not using your local weather station data, maybe you can take a look at the weather widget in my WidgetBoard app:
The weather data is sourced from Open-Meteo and based on your Homey’s GPS location.
How does this look?
It’s not live yet as just trying to get a layout sorted.
I have published a new test version of the weather underground app with the 5 day forecast widget. Any feedback welcome.
That looks great
that looks great!
i’m trying to connect my own station to it and what do i need to put in the bar that says Device when i create the widget?
First you need to add your weather station to Homey using the normal device wizard, then you’ll be able to select it in the widget.
I made the connection with the weather underground app on the homey, but it wil not show when i try to make a widget.
Ore is the way i discripe above not te way you mean?
Sorry, I meant to say you need to add the forecast device
That’s the one that will appear in the widget.
Tanks for te quik respond, unfortaly i did not get it working that way.
But one thing did change, now wen i go to device i looks like the is a device acording to the arow on the right side. But no discription and i can’t select it.
Strange, for me I see the weather device
Maybe try restarting the app and check again.
OR Just press the buttons, or change dark to light theme.
Restarting is not working and the light theme also nothing chainges, i wil try to uninstal the app tomorrow when i have time and reinstal en make sure i do everything in the right order.
i did a restart of homey and a reinstal of the app, but unfortunately i did not help.
i wil leave it for as is right now, i wil not put more effort in it and just work with a reagular weather app for the forcast.
