Hi Team,
How do you enable Bluetooth on Homey? All the advertising says Bluetooth is supported. Or Do i need an app that is supported which will enable the bluetooth functionality?
Hi Team,
For all things you want to add you need an app. Also for bluetooth devices. check apps.athom.com if you’re device is supported yet.
You need an App that uses the Bluetooth LE
fe these two use BLE:
https://apps.athom.com/app/com.mipow.playbulb
https://apps.athom.com/app/com.mi.flora
Generic Bluetooth and Bluetooth Audio is not implemented an probably never will with the change on Music (https://blog.athom.com/take-speech-music/) as many other system are far better on Audio and easily available. (vs limited functionality on Bluetooth short range.)
Thanks, let me give this a try!
They pick up the Flic signal, good thing! Just nothing I can do with it
