I currently have Hue lights throughout my home, each room with a Hue dimmer switch. These switches are all set up directly in the Hue app (not in Homey).
I’m moving soon, and I’d like to rethink my setup — especially the switches. Right now, it feels a bit messy having both Hue switches and regular wall switches in every room.
On top of that, I have a Homey flow that turns certain things off when we go to sleep, while my Hue motion sensors are set up in the Hue app to manage lights differently depending on the time of day. It’s getting confusing having automations spread across two systems.
I’m wondering what’s best practice here — should I move all lighting automations (switches, motion sensors, etc.) into Homey and stop using the Hue app for that?
What do you all do with your light switches and motion sensors? Do you let Hue handle it, or do you manage everything from Homey?
For connecting the lights and sensors, thats a choice.
Remeber that hue and homey create there own zigbee network. So if you have a limited number of non-hue zigbee devices you might want to strenghten your zigbee network by lso moving the hie devices to homey.
disadvantage of hue devices on homey (not much)
no firmware updates for devices
Some of the “scenes of hue re not available on homey yet
As I see it, the best way is to keep the Hue bridge and setup lighting scenes in different rooms through the Hue app and then bring the scenes into Homey.
This way, the firmware update will not be an issue.
I’m still not sure what the “right” way of dooing this is though.
I’m thinking of doing it the following way. Is this a decent approach?
Connect all Hue bulbs and Hue lamps to the Hue bridge
Setup scenes in Hue app and so not using Homey moods.
Install smart switches in place of all the switches in the house or perhaps install sonoff relays behind the old switches to make them smart
Don’t use the Hue Dimmer switches
Setup a flow in Homey for every switch that in turn activates scenes that are setup in Hue.
Setup a flow in Homey for every Hue motion sensor to trigger scenes in Hue.
I know I’m overthinking this, but I still see this as perhaps not beeing the best way of getting around this. It will end up being a lot of flows in Homey.
What are you guys thourghts on this and what do you do?
